Android 10 bug : Smart key not working after update
hegemony3
After updating to Android 10, smart key feature doesnt seem to work. it worked seemlessly on previous update. I have updated though OTA and factory resetted phone after update.. Any solutions...?
35 REPLIES 35
prashanth
Rising Star II
Its working for me, try to restart the device
hegemony3
i have done all that, but its still not working. its not hardware issue, i am sure because i do have a folder in home screen and when i press smart key, it selects that folder and opens it. so it is a bug... can any one help me to report this bug to devs..? thank you
a0920528530
It's not working for me either after updating to Android 10.
hegemony3
VS-KR
We need to know if the button is dead or if there is something wrong in the software.
To check the first idea, go to Parameters, Assistance, Examination/Check, Test keys.
You'll have to press Volume +, Volume - and Smart Key.
If you pass the exam, then something is wrong between Smart key and the software, but the button is still alive.
*The procedure is also available with the .12345+= method.
There isnt any problem with button, i have checked that through .12345+= method, its a pass. its purely a software bug.
