05-18-2021 05:27 AM
05-18-2021 06:20 AM
Benjamin BernhardssonPlease can you share long screenshot of your battery page which shows phone idle drain which will be make more clear exactly what is real problem here.Please tell us some basic information before asking for help:
- Model Name: Zenfone 6
- Firmware Version: .137
- Rooted or not: not
- Frequency of Occurrence: All day
- APP Name & APP Version (If your issue relates to the app):
I've been experiencing huge battery drain as of late. Really by doing nothing unusual at all.
I even factory reset my phone but it seems to have done nothing. Checked for apps and settings to cause this but nothing seems to help.
Can't figure this out myself. This happened to anyone else?
Abnormal battery drain
05-19-2021 11:16 PM
AmitGardeHi, sorry for the late answer.https://zentalk.asus.com/en/discussion/48263/abnormal-battery-drain
This can also be due to battery aging. You cannot expect same backup as it was from day 1 on 2 year old device. But yes if battery is draining in recent days in background than definetly there must be something running in the background. You have Auto start manager, and more power master options please try using that to avoid background battery drain. And see if you see some real diffrence.
Thanks!
05-20-2021 12:48 PM
Benjamin BernhardssonThen here i think you must get your battery checked from authorised service centre. And if needed and you are not satisfied also you can get it replaced. Or also they will look into if there is some other reason.https://zentalk.asus.com/en/discussion/comment/167355#Comment_167355
When I took that screenshot it showed my phone idle to be somewhere around 3-5% if i remember correctly.
And yeah i get the battery degrading but it all happened so fast after the 137 update. It's sort of like something is corrupted maybe that's causing this. Or atleast that's all i can think of.
05-20-2021 11:45 PM
