04-27-2020
08:10 AM
- last edited on
01-16-2024
12:45 AM
by
ZenBot
06-24-2020 09:26 AM
06-26-2020 12:28 AM
junxianjjTry other networks. If you can't find one single 5ghz network that it works with, then reset your wifi settings in system settings -> system -> reset options -> reset wifi, mobile & BT. If that doesn't help then factory reset. If it's still not working after this, then you have a hardware issue and need to contact ASUS for a repair@Anders_ASUS i have the same issue as rubennatanael, my wifi keep connecting and disconnecting to the 5ghz wifi.
if i remember correctly when on android pie , i can connect to 5ghz but it says no internet connection.
others phone works fine with this 5ghz band..
i only have this problem with rog phone 2. maybe because software bug?
09-19-2020 12:31 AM
