04-27-2020
08:10 AM
- last edited on
01-16-2024
12:45 AM
by
ZenBot
05-18-2020 09:25 AM
05-18-2020 11:35 AM
_jis_yes i restarted my phone several times since i last had the problem but not because of the slow wifi. i also restarted my phone several times when i first noticed the slowdown but it didn't help at that time so i'm not really sure what fixed it.https://zentalk.asus.com/en/discussion/comment/80974#Comment_80974
Did you restarted your phone in the meantime?
05-20-2020 01:08 AM
chrislingAlso, when moving away from my WiFi router the phone is not able to switch to the 2.4GHz channel but still camping onto the 5GHz, since the signal is too weak so it shows "Obtaining IP address" without an active connection.
I have to power cycle so that it knows to camp on to the 2.4GHz channel.
I'm using Netgear RAX20 WiFi router with smart WiFi turned on
paras0710Please fix switching from 5 to 2.4 GHz and vice versa. Zenfone 6 is not able to switch swiftly it disconnect with '?' Sign on wifi icon i have to switch it off and on again. i never had this problem with my previous phones also other devices including phones in my home is also working properly. The router i am using is mi router pro AC 2600 ut is powerful router with very good range still zenfone 6 having issues. Problem was there in previous firmware too. Did not check speed issue.
rubennatanaelAre you still experiencing slower download on 5Ghz?My Phone is ASUS ROG 2. Having the same problem here. 2.4Ghz connection is working well. 5Ghz download speed only clocked in 2Mbps but normal upload speed. Other devices running well in the 5Ghz wifi connection. Please advise with solution.
05-20-2020 04:07 AM
05-26-2020 03:16 AM
rubennatanaelTry to disable randomize mac. This is what we changed in the latest FW. You can change this by going to your network settings and click on the cogwheel next to your 5ghz connection. Under Privacy, change from randomize Mac (default) to Use device MAC.Yes I am. The problem still persist. I did all the reset wifi settings and restarted my phone. Checked all the router setting and other devices. Its only exist on the Asus Rog Phone 2.
