07-17-2020
11:33 PM
- last edited on
01-16-2024
12:56 AM
by
ZenBot
07-30-2020 02:47 AM
Christine_ASUSMy phone cant enter recovery mode and i did the volume down + power button and nothing's happening it only show asus logo then vibrates then it will go shutdown, but when i press volume up + power button it will enter fastboot mode and it will stay like that as long as i wont press the power button to shut it down and the service center said that my battery was the problem and i need to pay 60$ and i need to wait atleast 1 monthHi cruz.jazon69
Thank you for your reply. Kindly try some stay-at-home troubleshooting tips below:
A. Update your firmware version to the latest version
B. Change adapter and cable
C. Please try the following steps to access recovery mode for the Factory Reset:
0. Try to back up your data with USB cable
1. Power off the phone, then keep pressing "volume down key"
2. Press "power key" and stop press " power key" once you feel the vibration. Still keep pressing "volume down key"
3. Stop press "volume down key" once you enter [Android Recovery] Screen
4. Choose "Wipe data/factory reset">"Factory data reset"
5. "Reboot system now"
#Hardware Reset Guide
https://www.asus.com/support/FAQ/1006346/
Please note that once the steps are completed, all data, apps, settings and personal information will be deleted.
If the situation remain the same after the hardware reset, because your device once suffered a strong physical impact, please bring your device to the repair center and follow the diagnosis of the local engineer.
