My battery drains too fast
Model: ZE620KL
RAM: 1G
Firmware/APP Version: unknown
Frequency of Occurrence: unknown
Rooted: No
APP Name:
After using for 5 minutes,my battery went down from 100% to 90%. Is there any problem with the UI? Is it just my bad charging habbit. I have used this zenfone 5 for just a year , it is too early to have this battery problem.
6 REPLIES 6
@Jei_ASUS I assume that it was your first and last reply for me. thanks, it helps A LOT! (YOU LITERALLY DID THAT REPLY AND YOU THINK THAT IT'S ALL DONE MY PROBLEM IS SOLVED? NO! )
Jei_ASUS posted on 2020/1/31 10:21 Hi kittituch.melon, We would suggest that you test for a longer period such as one hour.
hello, that was it? you did tell me to your own suggestion. but you did't even care about yhe result thatvi gave you
