12-05-2019 04:13 AM
12-09-2019 12:48 AM
Safal posted on 2019/12/7 00:55 I've uninstalled those both fb app you mentioned. But still after that I'm getting only 4 hr SOT (Lo ...Hi Safal, Does this problem usually appear when using the phone or when the phone is in sleep mode? If while using the phone, does battery drain while using any specific apps? We would suggest you clear the background apps, and check how much battery is consumed from 100% after using the app for a certain time (e.g. 30 mins or 1 hour.) Please show me a screenshot of the battery usage after testing. Settings > Battery > Tap battery icon > Battery usage. If there are battery drain issues in sleep mode, please kindly follow the steps below and show us the screenshots. 1) Charge the phone to 100% before going to bed > remove the charger > Clear all apps in recent app list > turn off screen > the next morning before using the phone, please screenshot the two pages: a) Settings > Battery b) Settings > Battery > ""Advanced battery usage"" (tap the battery icon to access) 2) Tell me the battery variation: for example 23:00 (100%) > 08:00 (90%) Thank you 🙂
