10-30-2021 05:33 PM
10-31-2021 05:01 AM
11-01-2021 12:34 AM
11-01-2021 02:38 AM
martin.stavinoha87I did a factory reset, I didn't install anything at all, I charged it overnight and this morning as well happened again. Something happened to google I think, an update something that causes this. The problem must be solved.they'll recommend you to do a factory reset but I understand you'd like to avoid that
first try to identify newly installed apps and check these - maybe uninstall them to see if that helps
it could possibly be some barely used app which permissions were denied and because of that the app is misbehaving
try to run command top in the terminal to see if there is any app which is stressing your CPU
install better battery stats or similar tool (it will need some extra permissions enabled via adb) and then check if your device sleeps correctly or is awake and if that is the case, you should be able to identify the cause why it's awake and draining your battery
11-02-2021 12:51 AM
alexandru.sarauI see, it really seems that your device doesn't go into the deep sleep at all...https://zentalk.asus.com/en/discussion/comment/192554#Comment_192554
The phone detected that "google play store" is draining the battery, I force stopped it but it didn't have full effect I think it's not the only one that drains the battery.
0 minutes screen time, removed the charger and left overnight.
I hope an asus moderator will help me, maybe they can see through the log tool what is happening, because I don't know what to do with it.
The idea is that it discharges linearly, something it's draining continuously, you can see on the chart.
And this has happened for 3-4 days, before this the battery lasted 10 hours of screen time and consumed 2-3% in 9 hours of idle.
Please help, ASUS!
