Hi All,
Good day.
Could you please kindly help me update the system to the latest WW-90.11.162.50 for a check?
(settings> system > system update)
If this problem still appears, please kindly let me know.
Does this problem appear if using the stock adapter to charging?
I had a same problem.
The update WW-90.11.162.50 has fixed my mobile fast charging issues. Kept under monitoring..
I have observed another issue like Home icons are hidden, need to restart the mobile to fix the issue temporarily.
Please fix this also.
Regards,
Jagan
