Battery draining very fast
Ashy
Hi Team,
I like to know why my phone's battery is draining so fast... I replaced my screen and updated to android 10.. and now suddenly phone is draining very fat....can any one help....
4 REPLIES 4
burakterzi91
Rising Star I
Ashy
Hi Team,
Asus officials do not hear our voices. the two biggest problems of this phone ( battery draining very fast Android 10 and multitouch lag )
Ashy
Then what should we do now.... The phone started laging... Why these people are not listening to us... I will never buy asus again 😔
boboboy0309
Ashy
Hi Team,
我在更新後也出現了耗電和發熱問題...
觸控也是不理想...
ARP_ASUS
Community Legend II
Hi, when you say that your SOT(Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
Also share,
Firmware:
Go to setting => About => Software information.
