Asus 5z not charging problem
aspectlasta
Model Name: Asus 5z
Firmware Version: WW_100.10.107.87_20200520
Rooted or not:not
Frequency of Occurrence: Persistent
My asus 5z is not charging. Some times when I cover proximity sensor it charges and stops after few minutes. Not sure why this is happening but it is not charging even when my phone is off. The proximity sensor trick doesn't work everytime. I restarted my phone several times but the problem persists. Please give a solution for this as I won't be able to use my phone with this condition.
12 REPLIES 12
ramneek2110
Rising Star I
Your Flex cable might be loose. Open the phone and check for all cables are tightly fit in place
Rita
Maybe be it's time to clean the USB-C port.
The best way to clean a USB-C port is with a can of compressed air and a shaved toothpick or plastic dental pick.
AmitGarde
Community Legend II
Nivesh
@amitgarde3 when will New update come for 5z?
Most likely this month end though it totally depends on bug fixing so have to wait a bit longer 😊
Stay tuned!
