10-04-2020 10:22 AM
10-16-2020 03:07 AM
amitgarde3I gave Temporary solution. 😝 Just forgot to mention that. 😅https://zentalk.asus.com/en/discussion/comment/124826#Comment_124826
Indirectly you are saying dont use any of the features 5z has 🙄😅.....!! Except schedule charging 🤪
Limiting daily usage of some capable hardware for users is not solution here ! I feel battery optimisations with flagship hardware is all required and should be necessarily done 😁
https://zentalk.asus.com/en/discussion/comment/124841#Comment_124841
Yes this is useful feature though but i expect battery charge limit should be added to 5z with Zenui 7 which will boost up some battery life for 5z 😉 @Christine_ASUS
Thanks!
10-20-2020 08:26 PM
10-21-2020 02:39 AM
Christine_ASUSI agree mam we need just a battery fix update so that we can get more SOT in comparison to what we get now 🙂Hi friends
For battery percentage jumps up while charging, does the issue only occur in low battery scenario? If so, it is a normal behavior of battery charging while in the low battery, triggering from the switching charging current which is a battery protect mechanism in low battery.
I already tested what Debasish Sahoo had mentioned, yet my device battery performs properly in 70%-80%. Please check your battery performance. For more related information, kindly refer to the links below
https://www.asus.com/support/FAQ/1009546/
https://www.asus.com/support/FAQ/1009547/
10-21-2020 10:42 AM
10-21-2020 06:54 PM
