USB connection to pc not working - Phone is not detecting USB connection
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-09-2020 09:07 AM
Model Name: ASUS_Z01KD Asus Zenfone 4 (ZE554KL)
Firmware Version: Can't find it but I'll attach prints of all the about and relevant screens.
Rooted or not: No
Frequency of Occurrence: Current
I'm trying to connect my phone to my pc but the device itself is not detecting the USB cable properly.
I'm using the OEM Cable that came with the phone, still in perfect conditions and usually only used for charging, but also tried on a second one I have. Device charges normally without any troubles, but when connected to PC I don't get the USB Tethering option (it says that USB it not connected), and the computer itself doesn't detect it whatsoever, so I can't access the device files.
Tried on Windows 7 and 10 and Linux Ubuntu 18.04 and 15.04.
I tried looking for it on the device manager but can't seen to find it. USB Configuration is set to MTP and USB debugging is off. Tried turning the device off and leaving it be for a while and then back on, but still no result.
Any other option to try and fix the issue?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-10-2020 02:39 AM
Have you checked this out already?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-10-2020 03:56 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-10-2020 07:03 AM
Rameez221Drivers are already installed, I used to connect my phone to my computer and it used to work. Phone is not recognizing that it's connected to a computer (therefore not giving me option for USB Tethering). USB Debugging won't do anything because of it.Enable Developers option enable and also enable USB debugging, install proper driver in your PC
DeannnnnnYes, I did. But the problem doesn't seem to be on the computer, but on the phone instead.I could not post the link, please search: Asus [Phone] Device can not be detected when connected to PC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-10-2020 07:39 AM
luizhcgoncalvesChange your phone option as file transfer then it will workhttps://zentalk.asus.com/en/discussion/comment/87973#Comment_87973
https://zentalk.asus.com/en/discussion/comment/87964#Comment_87964
