Asus zenfone 4 selfie pro keeps restarting while erasing data.
joaovilela99
Model Name: Asus zenfone 4 selfie pro
Rooted or not: Not
Hello, i have a question, so i tried to do the Factory Reset (Removed the micro sd and sim) then the screen goes black with asus logo and says erasing, but the smartphone keeps restarting is it normal?
(Two hours doing that)
Thank You. 🙂
Falcon_ASUS
joaovilela99
  1. Model Name: Asus zenfone 4 selfie pro
  2. Rooted or not: Not
Thank You. 🙂
@joaovilela99
If it keeps restarting,  I would like to suggest you to bring back your mobile to our service center.
http://www.asus.com/support/Service-Center-All-Countries/
Also you can contact the local service center for help. The following is the contact information:
http://www.asus.com/support/CallUs#
