Anyone experincing heating lately?
RaginYak
Rising Star I
Currently on build: 420.112 have been experiencing heating a lot lately even on normal browsing. Anyone experiencing as such?
7 REPLIES 7
Another solution could be using the Mobile Manager app inside of your phone to do a scan and clear the background apps creating problems.
To find this you can go to Settings and type Memory Cleaner in the search bar, then almost all the way down you will find the Mobile Manager, this should be able to help too.
Mattias_ASUS
Hello @RaginYak
If you go to Settings > Battery, can you see if there any apps using unusually extra battery?
No nothing as such. Could it be because of the little crack just above the camera housing (I recently dropped it and there's a small crack despite Asus phone case 🥱)
