08-04-2024 03:16 AM
Hello,
other people report hearing me with a "metallic" filter and my speech is uncomprehensible most of the time.
If I speak up they say it's better, but the quality is still bad.
Here are the log files and all system specs:
https://drive.google.com/drive/folders/103hJbstt9oIjJDQcvuH775fzfIc5HQOm?usp=sharing
09-29-2024 10:51 PM
It sounds like you're experiencing significant audio issues with your microphone, resulting in a "metallic" filter and unclear speech. While I can't access external links, here are some troubleshooting steps you can take:
Check Microphone Settings: Ensure your microphone is set as the default recording device and check the input volume.
Update Drivers: Make sure your audio drivers are up to date.
Adjust Audio Settings: Disable any sound enhancements or effects in your system settings.
Test with Different Applications: Use various apps to see if the issue persists across all platforms.
Change Microphone: If possible, try using a different microphone to determine if the problem is hardware-related.
If these steps don’t resolve the issue, reviewing the log files for audio-related errors could provide more insights. Let me know if you need further assistance!
10-28-2024 06:48 AM
Driver Updates:
Noise Suppression:
Microphone Placement:
Test with Different Apps:
Check Hardware:
Audio Format Settings:
