Phone overheating with wireless charging
warawn2
For the z10 issue I'm noticing is if I let it charge wirelessly overnight it's still very hot in the morning even if it hit 100% hours ago. Any way to get it to stop charging when it's at 100? Seems like there's still current running when there shouldn't be
cbreze
Rising Star I
It's just maintaining the 100% charge once it reaches it. Shouldn't be hot and especially not very hot.  Mine stops at 90% because I have it set for that level. Maybe try setting your charging setting to stop at 90% or 80% and see if that makes any difference. In battery settings.  FWIW, I don't wireless charge, I plug in, maybe try that and see if any difference.
Boisenberry
Rising Star I
Mine gets really hot using wireless charging too, I just can't leave it on overnight (and I have mine set on 90% max charge). It was sort of a let down (wireless charging) but better than nothing.  If the phone is actually overheating and shutting down, I'd contact support.
