Irritating notification sound
Saabengan
hi, my phone is almost always giving a kind of notification sound. It doesnt seems to be a system or app alert. Can't get rid of it. I understand it could be Android related but I'm trying to ask here. Best regards Bengt
Mattias_ASUS
Hello Bengt!
Thank you for your question.
In some cases an app that has notifications might push them after a while when they haven't been seen, which might use a notification sound, do you have any notifications in the notification bar when the sound triggers?
Is your phone in Sound/Vibrate or mute when this happens? And what firmware are you on? You can check the firmware by going to Settings > System > About Phone > Build number
Hi, the sound is only silenced by the ringing volume or mute. Sounds even if all apps notifications not are allowed. No notifications. The software version is android 15 and 35.0604.0404.109. best regards Bengt
Hi, I've had similar problem:
A short sound was triggered repeatedly in some situations, no notification or anything displayed, though. Until I found out that it only happened, when a) my badge was near the phone and b) NFC was turned on. So it war the only signal of a NFC-signal that was not recognized.
