04-06-2024 09:27 PM
My front camera wont work after the latest update including other apps that used front camera like instagram/WA/Line/Bank/E-Wallet etc.
I've already cleared the cache, even went through factory reset my phone and the result still the same. The smmi test also crashed after testing the front camera.
Build number : WW_33.0220.0220.43
Solved! Go to Solution.
3 weeks ago
Update : The Problem was solved after i went to the service center, they changed the camera & now its seem to be working fine.
04-09-2024 12:31 AM
Hi @Lotus1,
This seems like a HW issue. I'd recommend you contact your nearest ASUS service center and get your device examined.
3 weeks ago
