Edge tools - supported applications
vilwen
Some applications does not seem to be compatible with the edge tool. One perfect example is the setting "application", which feels very odd.
6 REPLIES 6
Mansi_ASUS
Hey @vilwen,
Could you share a screen recording of the issue?
As you can see. Settings is not available here
Mansi_ASUS
Hey @vilwen,
When you slide open the edge tool, the 'settings' app is available by default at the bottom of the edge tool drawer, although, yes, it only opens up the settings for the edge tool.
Yikes I couldn't not see that you are able to scroll. And it is not shown by default as you can see.
There is another app I would like to add aswell and not able to. But that is perhaps cause the app does not support being shown in a small view?
