Battery drain
Bulletdracer
Battery on this phone is really wierd.
If i charge to 100 it will drain quickly down till 90-80 and then stop
Am i the only one with this problem?
17 REPLIES 17
Phone is back. They could not find the problem. Really bad. How much does cost for the to just change the battery.
I have same problem. Very fast draining from 100% to 90% and then it's quite ok. Restart/reset doesn't help at all. I've 256 gb version.
I send mine for service. Hope they change battery or just fixwa the phone. Will ley you now how it goes
