Battery drain
Bulletdracer
Battery on this phone is really wierd.
If i charge to 100 it will drain quickly down till 90-80 and then stop
Am i the only one with this problem?
17 REPLIES 17
Mansi_ASUS
Hey @Bulletdracer,
I'd suggest you observe the battery drainage till about 50%. See if the battery drainage is quick or not.
Only from 100 to 90-80 is drain. Then it stops and behaves normal
Drissou
A while ago I also had this problem, so I went to look in the settings to see which application was draining the battery, I realized that it was the network. After optimizing the battery options as much as possible, I restarted my phone and HOP! I never had this problem again and since then the network consumes nothing at all in percentage terms. Bye
I dont see any high battery usage from network. It is optimized
