zenbook ux325 i5 short battery life
rushy7
System: windows 10
Battery or AC: battery
Model: ux325 i5
Frequency of occurrence: all the time
Reset OS: yes
Screenshot or video:
Detailed description:
Im getting about 6-7 hours battery on light browsing on 40% brighness ,this is not very good .i only got the zenbook because it promised great battery life.It cost a lot of money so im not very happy
RAJU_MSC_MATHEM
Zen Master I
rushy7
  1. System: windows 10
  2. Battery or AC: battery
  3. Model: ux325 i5
  4. Frequency of occurrence: all the time
  5. Reset OS: yes
  6. Screenshot or video:
zenbook ux325 i5
disable running background applications.
delete all scheduled tasks if possible.
use SSD for windows OS.
set unwanted services to manual
Blake_ASUS
Community Legend II
Hello rushy,
May you double check if you have update the latest BIOS?
Also, since your device is new, there might be Windows update running in the background,
please kindly check and wait until all updates are complete.
Let me know if it gets better.
You may also check in task manager to see if there is specific program or function that is using more power than you expected.
rushy7
Ive had it for nearly 2 weeks so its done some updates and also a bois update and still its the same between 6-7 hours
