06-27-2020 04:49 AM - last edited on 01-16-2024 12:59 AM by ZenBot
06-28-2020 03:51 AM
06-28-2020 04:17 AM
06-28-2020 04:19 AM
LiviuThanks for your help! Yes I see it can be an issue with others too. It's just really annoying when you have a 4K screen for clarity and have grain on it.Hmm, so you're not clicking, just touching it and it make that noise? If that's so, something is wrong. Mine doesn't make any noise when tapping on it without putting pressure to do clicks.
Regarding the grainy screen, it's a well know issue. There was a thread here with tens of comments, but It's gone.
There are other manufactures that have the same issue. Do a search on HP Spectre 13 QHD grainy screen. I cannot post full links in comments.
Notebook-Video-Display-and-Touch/Spectre-13-QHD-faulty-grainy-display/td-p/6913348
06-28-2020 04:26 AM
06-28-2020 04:45 AM
LiviuYes I couldn't believe the webcam is 720p. And no SD card slot is crazy to me when it is aimed at content creators.You should definitely send it to your local Asus service center to have a look at it. Mine is robust but I haven't use it at all as I use a mouse, but It may be an issue if it goes that loose with time.
There are quite few issues with this laptop that we try to solve here with the Asus staff. The webcam isn't great either for a +3000 Euros laptop. Besides the gray lines and green flickers, the quality is grainy as well, and other software issues.
