Zenbook Pro Duo GLOWING HOT in standby
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-21-2022 02:41 PM
Battery or AC: AC
Model: UX581GV
Frequency of occurrence: 3 - 4 nights per week
Reset OS: ?
Screenshot or video:
Detailed description:
Hi everyone,
when I put my computer to sleep and come back some hours later, it sometimes is blazing hot (you can't toouch the underside). When I try to wake it by pressing the power button, it doesn't simply wake from standby; it seems to boot from hibernation, even that is disabled and the computer was plugged in all the time.
MyAsus says that all drivers are up do date. I know this is a Win11 beta, but it also happened on Win10 and the final Win11.
I'm really worried about it catching on fire. Don't know what to check.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-21-2022 06:25 PM
Sonny1983@Sonny1983
- System: Win11 beta
- Battery or AC: AC
- Model: UX581GV
- Frequency of occurrence: 3 - 4 nights per week
- Reset OS: ?
- Screenshot or video:
Hi everyone,
I would recommend you to check if the laptop has more dust causing it to overheat.
You can refer to the following FAQ for troubleshooting.
[Notebook] Troubleshooting - Overheating (Fan) issue of ASUS laptop | Official Support | ASUS Global[Notebook] Troubleshooting - Laptop does not wake from Sleep or Hibernate mode | Official Support | ...If the situation remains the same, according to what you described, please contact ASUS repair center in the country of your residence: https://www.asus.com/support/Service-Center-All-Countries/. Sorry for any inconvenience it may be caused.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-19-2022 04:24 AM
If you use the power button to put it to sleep, do not close the lid immediately. Wait a few seconds until the power button stops flashing, and then you may close the lid.
Let me know if that helps your situation so I know if that is the cause - it would appear to be a sleep state problem by either Windows or the motherboard firmware/BIOS.
If that is the cause of the problem then I really think ASUS is able to do something about it to fix it in firmware.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-19-2022 04:45 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-26-2022 03:44 PM
@potatosubwoofer Yes, the settings for battery and AC are identical.
My next step is to do a clean install of Win11 (final version). I already downloaded all ASUS drivers. I will report in a couple of days...
