Zenbook DUO 14 - ScreenPad Plus - capture and placement not working correctly
Axiom
System: win10 current 21H1 19043.1110
Model: UX481FLY
Detailed description:
Part 1:
When using the screenpad to simply open the "Number Key" tile, it will randomly choose a size or position - and will only remember "last state" once out of a hundred attempts and will of course be different on next use.
I would like it on the last third of the screen on the right (where it would traditionally be on a normal keyboard). But this seems impossible.
After moving it (and sometimes resizing it), the next time I open it, it will be anywhere but where I had it, and sometimes can populate two columns or one column. Nothing else is present on the ScreenPad Plus - but it will overlap - or not - if something like a file folder is open in one or two columns.
Part 2:
Task Group.
A similar issue occurs trying to create a "task group".
Open app on main top monitor, open a file folder and place on the preset left two columns of screenpad - open number key on right 3rd column. Select matching patterns in the TaskGroup options - Hit capture.
Main monitor keeps app (good), ScreenPad will literally switch 2 column folder and 1 column number pad.
When saved, it then opens this wrong configuration.
side note - there also seems to be no way to manually rearrange the captured objects within the capture window.
Any one have any ideas?
0 REPLIES 0
