a week ago
Good morning,
New purchase of the above computer and I'm very happy with it so far except for the built in camera which, although worked perfectly when I first started using it has now stopped working completely.
The two "holes/lenses above the screen were black at first then they went half black half orange, then orange and now they are back to half and half again, confusing?
I have been through the help section and done everything suggested but to no avail so any help or ideas from the group would be great, thank you.
Solved! Go to Solution.
a week ago
Ignore my post please as my wife has just come over to my desk to do some polishing and looking at the laptop noticed a slider just above the lenses, slid it over and voila! My camera works again.
Sometimes it's the simplest thing isn't it.
Thanks for looking and I hope this helps others pulling their hair out. 🙂
Have a good day everyone
a week ago
