06-05-2021 11:47 AM
06-07-2021 01:32 AM
RAJU.MSC.MATHEMATICSYeap, I did so several times but now i'll try once morehttps://zentalk.asus.com/en/discussion/comment/170215#Comment_170215
did you resetted bios settings to default settings, after updating of bios firmware?
So now go to bios, do reset bios , save and exit. power off .wait for 2 minutes, then go to bios, adjust settings as you like save and exit, boot windows as normal.
06-07-2021 01:43 AM
06-07-2021 01:47 AM
s.g.parvanianthen you may to take your laptop to nearest Asus service center and get checked from technician.No, nothing changes
The fan stays at full speed
06-07-2021 02:02 AM
06-07-2021 02:09 AM
s.g.parvanianyour laptop model and my laptop model are much different, but both laptops are using intel processor onlyI've found same problem with Asus laptops descripted on Reddit
The starting point was turning the laptop on unplugged after being charged overnight. Fan stays on max speed whatever you do, while CPU usage and temp are low
in one case it was solved after '"full shutdown", whatever in means. I used to empty my laptop battery and leave unplugged overnight, I also used long-press power button off. No effect.
in other case this porblem was solved after disassembly for CMOS reset purpose, but the thing that helped was checking the cabels, in particular - the monitor connection cable.
Im still not ready to disassembly my laptop. will keep looking for a cure
