USB-C/thunderbolt problem no signal to external display
YukonCharlie
System: W10
Battery or AC: AC
Model: UX391.FA
Frequency of occurrence: Always
Reset OS:
Screenshot or video:
Detailed description:I have had my computer for almost 2 year. I have never had any issues with the docking station (USB C) were i have my external monitor and mouse and keypad connected. For two weeks ago the display stoped working. It lights up when i am connectint to the docking station but it gets no signal so after a couple of seconds it turns of.
I can also say that there is nothing wrong with cables or dock. The mouse, keypad and everything else works just fine...But not the display.
I have also tried to connect my other laptop (lenovo x250) and with that laptop everything including display works. So, there is nothing wrong with the equipment.
27 REPLIES 27
YukonCharlie
I had w10 when it started. After trying everything i last week reinstalled everything and then with w11, with hope that it would be solved:)
I wonder if there could be something wrong with the hardware..But the computer had been connected to the dock the last three months so nothing should have happened.
Blake_ASUS
Community Legend II
Hello Charlie,
You are able to use any Type C function other than display.... so should not be hardware issue.
Please share the Win11 result with me and I will consult more about it as well.
YukonCharlie
Hello,
what w11 result do you need? I have exactly the same problem with w11 as with w10...Everything with USB C works just fine except the display....
What i can see when running the thunderbolt software, there is no device connected. When running my other computer there is a device in the list with the same software. I dont know if it says anything but maybe 🙂
hello, i have the exact same problem. everything works via the Thunderbold connection except the monitor. I have a zenbook 13 with Windows 11.
The support advised me to reinstall the driver .. I should also start the system by pressing the start button. This also leads to the function. But only until a restart. Does anyone have a solution?
Blake_ASUS
Community Legend II
YukonCharlie
Hello,
Hi Charlie,
Sorry I misunderstood. I thought you just upgraded to Win11 to test for the difference, but you have already done it.
Any way, I have send you PM, please kindly help to reply.
