ScreenXpert Control Panel 3.0 Extension - Buttons and Sliders Overlapped
nanihothearts
System: Windows 11 Home
Battery or AC:
Model: Zephyrus Duo 16
Frequency of occurrence: Everytime
Reset OS: Yes
Screenshot or video:
Detailed description:
nanihothearts
Detailed description: So the control panel that opens in 2nd screen when using popular adobe apps looks bulged and the buttons, sliders overlap one another making it hard to use.
Please see enclosed screenshots. Does anyone know how to revert this into proper fit?
Falcon_ASUS
nanihothearts
  1. System: Windows 11 Home
  2. Battery or AC:
  3. Model: Zephyrus Duo 16
  4. Frequency of occurrence: Everytime
  5. Reset OS: Yes
  6. Screenshot or video:
@nanihothearts
Please kindly provide the information below so that we can better assist you.
1. What is your laptop's full model name?
How to find Model Name
2. What is the system version and ScreenXpert version you are currently using?
Which version of Windows operating system am I running? - Microsoft Support[Notebook] Asus ScreenXpert (ScreenPad Plus) - Introduction | Official Support | ASUS Global >>14. How can I check the version of ScreenXpert?
a. Right click Windows Start menu and select "Apps and Features".
b. Search "ScreenXpert".
c. Click "Advanced options".
d. Then you can check version here.
