Sandisk extreme pro v2 cannot read/write to 2000 mb/s as advertized on UX8402ZE
FongPoui
Rising Star II
System: Windows 11
Battery or AC: Both
Model: UX8402ZE
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:I bought a 2TB sandisk extreme pro version 2 whose the speed can be up to 2000 mb/s if connected via usb 3.2 Gen 2. The sandisk technical support adviced me to make a low level format and I did it via windows disk format.
This is a test result via Crystal Disk Mark version 8 before my low level format.
15 REPLIES 15
FongPoui
Rising Star II
The test result is that has no change to the speed after the low level format of the external disk...
FongPoui
Rising Star II
Red flash indicate that the sandisk extreme pro v2 is connected through usb port type A (the only one port with UX8402ZE which advertise that it is a usb 3.2 Gen 2.
Falcon_ASUS
FongPoui
@FongPoui
I have reported to the relevant unit for confirmation.
In order to avoid misunderstanding, I would like to confirm with you again. Is this the SSD you bought?
SanDisk Extreme PRO® Portable SSD V2 USB-C, USB 3.2 Gen 2x2 External SSD | Western DigitalWhat is the BIOS and system version you are currently using?
FongPoui
Rising Star II
@Falcon_ASUS
UX8402ZE.302
