OLED screen quality
gszkop
System: Windows 10
Battery or AC: AC
Description: OLED screen quality
Model: Asus Zenbook Pro Duo
Frequency of Occurrence: Always
Reset OS: No
I bought Zenbook Pro Duo and the first thing that caught my eye was the uneven backlight of the screen. When displaying e.g. 5% gray, using a video on YouTube at this link https://www.youtube.com/watch?v=Qi4Wy7vE8-o&t=124s and reducing the screen backlight, you can see a large unevenness in the brightness of the backlight. I will point out that the problems I describe can be seen best in a dark room, when working during the day the problems are not visible or are very poorly visible.
48 REPLIES 48
braintheboss
Last edited by braintheboss on 2019/11/3 18:07 Its evident screens quality are crap
gszkop
braintheboss
gszkop posted on 2019/11/3 19:02 This is my screen with white
Its blur and far. For see if matrix is visible as you can see in person you have take it closer and for avoid camera overexpose due so white at screen you should let task manager not maximize. Similar I did in my captures :/ Anyway your screen have better look about banding comparing with mine. But is not a surprise. I have luck taking the worst with this model 😞 I'm not worried since I will send to replace screen but this is a lottery
gszkop
next photo of my screen.It is grain ?
braintheboss
gszkop posted on 2019/11/3 19:36 next photo of my screen.It is grain ?
Thank you very much. Unfortunately for you, its grain. Really your camera is good thinking didnt add any artifact. You can see dark pixels at same distance along all screen. Light colors never are solid and uniform. Its really a big shit from ASUS
