no wifi connection available suddenly, and camera ano longer works
ZT-0f34ba61
System: Windows 10 64 bit
Battery or AC: Batter and ACV
Model: Zenbook 14 UX433f
Frequency of occurrence: persinstent failure
Reset OS: no
Screenshot or video: can provide
Detailed description:Suddenly my zenbook has no wifi, and it seems there is no wifi network driver or bloetohth availaable, only get connect thru cable connector. After som retstaert the camera is no loger working as well. I have donloaded wifi driver kit installed it rebooted but problem persist.
16 REPLIES 16
Blake_ASUS
Community Legend II
Hello mikael,
Was there any update or modification before the issue occurred?
Please kindly check if your BIOS is updated, and run Windows update as well.
Please also enter device manager to see if the Wifi card, bluetooth and camera are listed there or if there is any error message with these devices.
simon_diemert
I experienced a similar issue over the weekend (starting on 2020-12-05).
The device manager shows the Intel Wireless AC 9560 network adapter (so I assume the hardware is intact) but I receive the following error message under device properties:
Device manager tells me the driver is already up to date.
I am currently using a hardwired ethernet connection, however, this is not ideal for my setup. Please advise.
Blake_ASUS
Community Legend II
simon.diemert
Hello Simon,
Which model do you have?
And have you tried to update BIOS and then reinstall the driver again?
simon_diemert
Blake_ASUS
https://zentalk.asus.com/en/discussion/comment/138108#Comment_138108
Hello Simon,
I have the Asus Zenbook 14 UX433FA. Running Windows 10.0.19042.
I have not done a BIOS update. How do I do this?
