No sound (output/input device) after computer reset on UX581GV
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-31-2020 05:06 PM
System: UX581GV.308
Battery or AC: Both
Model: UX581-XB74T
Frequency of occurrence: Always after Reset OS
Reset OS: Yes, 2004 or 2009
Screenshot or video: Yes
Detailed description:
Windows Version: 20H2 (2009)
OS Build: 19042.610
After OS Reset there is no sound and Output/Input Device:
Device Manager is showing me the following:
(Software Update doesn't help)
Temporary workaround to get the sound working is to update SST OED driver from Windows Catalog:
Driver would be updated to version 10.24.2694.200 even though I get the following error below:
(driver error still there)
But now my sound is back (even after reboot):
However, since this is a temporary fix, how do I fix it properly?
Battery or AC: Both
Model: UX581-XB74T
OS Build: 19042.610
19 REPLIES 19
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2020 02:43 PM
It looks like the computer Intel Audio Controller is on driver version 10.24.0.3694
But, Intel SST OED is stuck on driver version:
So I downloaded Intel Media v. 10.24.0.3694 from Windows Catalog
a. Extracted .cab file to a folder
b. Updated Intel SST OED to v. 10.24.0.3694 from that folder through "Let me pick from a list of available drivers on my computer" and then Have Disk
Still got the Update Driver Warning
and
but the drivers was loaded:
and the sound comeback right away
c. Rebooted the computer
d. Sound is still here
but, Device Manager is still showing me that Intel SST OED has an error
and MyAsus app is still showing me that there is a driver error
So, the above is still a workaround but not a fix.
and
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2020 06:50 PM
Hello puzzeld,
May I know what kind of reset did you conduct?
is it factory OS reset or a new OS reinstalled?
also, was your windows version 20H2 before the reset?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2020 06:58 PM
Reset This PC (with Remove everything.)
OS before reset was Windows 10 20H2 (2009)
Factory Reset though "F9" resets the PC to Windows 10 2004 with the same no sound result.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-02-2020 02:56 PM
Well... finally I think I found the the fix for the no sound after OS reset. It is not Asus fix but something I found it by experimenting with the problem.
Here are my detailed steps of what I did.
a. OS reset
b. After OS reset and initial setup, here is the condition of the UX581-XB74T
No sound or output/input device
(MyAsus Software Update does not help)
c. Run Windows Update
Enabled "Receive update for other Microsoft..." in Advanced options and run Windows update again
d. Downloaded Intel iSST v10.23.0.2672 from MyAsus
and extracted files to its default folder
e. Search "Intel Media 2020" in Microsoft Update Catalog and downloaded Intel Media v 10.25.0.4040
Extracted .cab file to Intel Media 10.25.0.4040 folder with 7 zip
copied "Install.cmd and pnputil.exe from SmartSound_DCH_Intel_W10_64_v102302672 14077 folder
and pasted the into Intel Media 10.25.0.4040 folder
f. Uninstalled Device Intel SST OED and Audio Controller from Device Manager
(just in case it asked you to reboot the computer, DON'T reboot it)
g. Run Install.cmd in PowerShell from Intel Media 10.25.0.4040
h. Reboot the computer
You will notice that there is still no sound after reboot
i. Uninstall Intel SST OED from Device Manager
j. Update Intel SST Audio Controller to v 10.25.0.4040 from folder Intel Media 10.25.0.4040 in Download folder with "Have Disk" option
You will get "Update Driver Warning" but accept it by clicking "Yes"
Driver for Intel SST Audio Controller will updated to v.10.25.0.4040 and will also add Intel SST OED back
k. Now, update driver for Intel SST OED from Intel Media 10.25.0.4040 folder located in Download folder with "Have Disk" option
You might get the "Update Driver Warning" again so accept it by clicking "Yes" and the driver will be installed successfully
You will notice that the Intel SST OED Driver was installed successfully to v 10.25.4040.217 and the driver warning beside Intel SST OED will be gone and what is the most important the YOU HAVE YOUR SOUND BACK without any errors.
Result: Sound is back without any errors
That's all folks
(Special thanks to "Liviu" for some good suggestions that helped me make this happen)
a. OS reset
That's all folks
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-04-2020 07:53 PM
Hello puzzeld,
Thank you for the update.
I have reported to dig in more about it.
- « Previous
- Next »
