My wallpaper in my ASUS ZENBOOK PRO DUO
POSEIDON24
ASUS, plz fix my my wallpaper issue.
Whenever I apply new wallpaper to my home screen , after 1 or 2 min it reveted to my previous wallpaper(and slideshow is off)  and i can't change it. I tried many method search on internet but I cant't fix it. including turn off onedrive wallpaper syncing setting and also formated my laptop as well.
Falcon_ASUS
@POSEIDON24
May I inquire about the complete model of the laptop you are using?
How to find Model Name
Please try going to
Settings > Personalization > Lock Screen
and change the setting to "Picture"
then confirm if the issue has improved.
POSEIDON24
My model is Zenbook UX8402ZA_UX8402ZA
ASUS Zenbook Pro Duo 14 (2022)
The issue is with the home screen wallpaper not with the lockscreen wallpaper , as i tried your method that does' t work
@POSEIDON24
May I ask which system version you are currently using? Have you updated it to the latest version?
Could you please provide a video showing the situation where the issue occurs for me to confirm?
