01-31-2023 02:24 AM
02-01-2023 01:51 AM - edited 02-01-2023 01:54 AM
Hello, suleman__47 and thank you for reaching out.
Could you please provide full the model name (for example, FA506IH), the BIOS version, and details of the situation?
May I ask if the abnormal sound is caused by specific software or does it happen all the time when booting on the laptop? Will the sound persist if an external earphone or speaker is connected?
02-02-2023 10:06 PM
As the audio enhancement algorithm is implemented on your laptop, any error in the algorithm filter may be outputted to the speaker making a faint buzzing noise when the speaker volume is low. This is a normal phenomenon and does not indicate an issue with your device.
Regards,
Will
