Green or gray artifacts on screenpad plus zenbook pro duo UX581GV-XB94T
Xaryi
System: Windows 10
Battery or AC: AC
Model: UX581GV-XB94T
Frequency of occurrence: Sometimes
Reset OS: no
Screenshot or video:
Detailed description:
Sometimes I have green or gray artifacts that appear on some parts of the screenpad +. It seems to target a certain range of colors and move with the videos, images I move accross the screen etc...
I rebooted many times but It does not work at all.
14 REPLIES 14
Blake_ASUS
Community Legend II
Hi there,
Does the same thing happen on the main screen?
Can I have a video of the issue ?
And does this issue happen out of a sudden or since you have been using the laptop?
Xaryi
Yes it can happen on the main screen too. I had this issue since I bought the laptop but it started to show more and more often.
The next time it makes it I will film it.
MotoWiZ
Rising Star II
@Xaryi check if you have HDR enabled, and if so disable it, sometimes this greenish colouring occurs due to HDR settings.
Xaryi
I don't use HDR
