Does Zenbook UX330UAK have MST or NOT???
marym
System: what is this supposed tomean, OS and version or what?
Battery or AC:
Model: Zenbook UX330UAK
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:
I've spent way too much time trying to find the answer to a simple question: Does the Zenbook UX330UAK running Windows 10 support MST or not? Real simple question. Yes or no. I need this for supporting multiple external monitors AS SEPARATE AND DISTINCT DISPLAYS, NOT DUPLICATED, on Windows 10. After a whole lot of work I've found a hub that should support this IF the USB-C port supports MST. So, does it?
Blake_ASUS
Community Legend II
Hi Mary,
The USB ports on this model does not support display export.
The only port you can use to connect external monitor is the HDMI.
