battery drains fast in hibernate mode(close lid)
benaya7
Reset OS: No
Frequency of Occurrence: Always
Model: ux480fd
Description: battery drains fast in hibernate mode(close lid)
Battery or AC: Battery
System: Windows 10
the same question was asked before here: ( https://www.asus.com/zentalk/thread-295101-1-1.html)but for some unknown reason, the support group decided to answer via a private message to the asker. I have the exact same problem as mentioned in the link above, and same laptop model. for comparison, my 6 years old thinkpad can stay in sleep mode(close lid) for a week, and it only has about 40wh battery, while my ux480 has 70wh battery, and after a night with closed lid the battery is empty. I checked the settings, and it's set to sleep when I close the lid...please help
Blake_ASUS
Community Legend II
Hello benaya7, May you provide a screenshot of your power options> choose what closing the lid does ? May you try to find out more what was happening during the night? Was the device waken up, by which program and so on... Thank you.
benaya7
Last edited by benaya7 on 2019/12/19 08:46 when I sleep, my device sleeps as well, so nothing happens at night...:D(not that I know of) I attached the screenshot, I hope it helps...
Blake_ASUS
Community Legend II
Dear all, We have been investigating similar cases and found it's related to Microsoft. The solution is now in progress with the cooperation from both side. Please kindly enter your Power Options>Edit Plan Setting>Changed advanced power settings>Sleep>Hibernate After Changed both from "180 minutes" to "30 minutes". Let me know if any. Thank you.
