[ASUS System Control Interface V2] V2.2.18.10 UAC Prompts at startup.
darktears31
System: Asus Zenbook Pro Duo
Battery or AC: Battery
Model: UX581GV
Frequency of occurrence: always
Reset OS: Yes
Screenshot or video:
Detailed description:
ASUS System Control Interface V2 got updated in my system and again the UAC prompts on startup are appearing again. This was an issue that was fixed in recent releases of ASUS System Control Interface but now is coming back to annoy us.
Version V2.2.18.10 has the issue.
Can we get someone to fix it again?
13 REPLIES 13
darktears31
cc @Blake_ASUS since you handled the report and got us the fix last time.
Blake_ASUS
Community Legend II
Hello darktears31,
Yes, I remember this.
Please try to extract file by using 7-zip.
and remove the old driver file, install the one extracted by 7-zip again.
or you may just use Windows update to install this 2.2.18 version, it would be easier
Thank you so much.
darktears31
No luck, same issue.
Blake_ASUS
Community Legend II
Hello darktears31,
Which one did you try? 7-Zip or Windows update?
Please also make sure that you delete the old ones, and revert back to .16 completely.
After reboot, install the new one extracted by 7-Zip,
Run Install.bat by powershell, then reboot again.
We try about 4 time, it's working, may you try again?
