Whats dockstation compatible with zenbook pro ux582l ? I need fast ethernet rj45 connector .
toneclaudio
System:
Battery or AC:
Model:
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:
toneclaudio
System: windows 11
Model: ZENBOOK PRO UX582L
Detailed description:I need fast connector ethernet rj45. Whats brand and model is compatible with my zenbook. UX582L?
Falcon_ASUS
toneclaudio
  1. System: windows 11
  2. Model: ZENBOOK PRO UX582L
@toneclaudio
I would suggest that you consider purchasing a USB to RJ-45 cable for use.
Amazon.com : usb ethernet adapterThank you.
