webcam led indicator
loonogs
System: Windows 10
Battery or AC: AC
Description: webcam led indicator
Model: K541
Frequency of Occurrence: Always
Reset OS: No
Hi, i have a question, the laptop does not come with a caps on led indicator, how can i use the webcam led indicator to indicate if caps lock is off or on ? the led should not be hardwired to the camera, it should be switched on by code, how can this be modified to give me what i want. i never use the camera so that led indicator is redundant at the moment
Blake_ASUS
Community Legend II
Hello loonogs, Webcam LED indicator need to be support by hardware fundamentally. https://www.asus.com/me-en/Laptops/K541UJ/ From spec, your model is equipped with indicator. Please provide your complete Model name or PM me your product serial number. I will double check your laptop. May you test your camera as well? Turn on the camera, see if the indicator lights on simultaneously. Thank you for messaging us. Have a nice day.
