03-15-2023 12:24 AM
Recently, whenever I started my laptop, the fans made a lot of noise and the keyboard deck was heated even if there wasn't any demanding task running.
Yesterday, a rather concerning noise started coming out as if the fans are colliding with something (like a small wire). Can't say until I open it, could be dust.
My warranty ended 3 months ago unfortunately and there doesn't seem to be any way of extending that.
I was going to purchase a torx screwdriver for this very purpose but don't know which size it is.
Can anyone help me out with this?
I checked the laptop manual but there doesn't seem to be any info whatsoever regarding this.
03-15-2023 05:41 PM
@Razor54672
From our standpoint, we do not recommend that you disassemble and repair by yourself.
We would suggest you bring back your laptop to our service center for further confirmation.
