VivoBook 14 charger grounding issue
yusufkhanZA
System: Windows 11
Battery or AC: AC
Model: M413U
Frequency of occurrence: Every time
Reset OS: N/A
Screenshot or video: Charger picture
Detailed description :I can feel a tingle on the metal lid when the AC charger is plugged in. This is with the included 2 pin charger. It was purchased in South Africa. Is this a known issue? Is there a 3 pin charger available?
4 REPLIES 4
RAJU_MSC_MATHEM
Zen Master I
yusufkhanZA
  1. System: Windows 11
  2. Battery or AC: AC
  3. Model: M413U
  4. Frequency of occurrence: Every time
  5. Reset OS: N/A
  6. Screenshot or video: Charger picture
Is that charger is came with Laptop or did you purchased sepeartely.
If purchased means where did you bought in local shop or from asus service center
yusufkhanZA
RAJU.MSC.MATHEMATICS
https://zentalk.asus.com/en/discussion/59622/vivobook-14-charger-grounding-issue
It is the included charger
RAJU_MSC_MATHEM
Zen Master I
yusufkhanZA
https://zentalk.asus.com/en/discussion/comment/209674#Comment_209674
Then moderator from Asus person should confirm that the charger issue or not
Falcon_ASUS
yusufkhanZA
  3. Model: M413U
  5. Reset OS: N/A
@yusufkhanZA
According to what you described, please contact ASUS repair center in the country of your residence: https://www.asus.com/support/Service-Center-All-Countries/.Sorry for any inconvenience it may be caused.
