ScreenPad problem
pierre_gain
System: Windows 10
Battery or AC: AC
Description: Freeze main screeen
Model: S432FA
Frequency of Occurrence: Always
Reset OS: No
Hi, When I try to activate the screenPad, with F6, the display on it is ok, but the toolbar at the botton of the main screen is masked, and the machine is nearly blocked. WHen we disable the screenpas with F6, after several second the function is normal again. Is there a specific instalation, or an update of drivers? For now, it is not working for me... Regards.
Blake_ASUS
Community Legend II
Last edited by blake_ASUS on 2019/11/12 15:45 Hello pierre.gain, Please kindly refer to below FAQ. https://www.asus.com/support/FAQ/1041344 Let me know if there is any other issue and which step were you at. Thank you so much.
