heating issue
Umar301
System:
Battery or AC:
Model:
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:i have Asus Vivibook S14 Model S431F. its heating like hell even on normal use. please suggest solution for extra overheating.
RAJU_MSC_MATHEM
Zen Master I
Umar301
  1. System:
  2. Battery or AC:
  3. Model:
  4. Frequency of occurrence:
  5. Reset OS:
  6. Screenshot or video:
heating issue
make sure builtin FAN is \running ?
Also make sure no appliactaions are running in background.
delete of disable all possible tasks under task scheduler.
make unwanted services startup type to manual
Umar301
RAJU.MSC.MATHEMATICS
https://zentalk.asus.com/en/discussion/47700/heating-issue
thank you sir for your kind reply. i have checked my laptop through fan monitor chart and it shows nothing, that means my laptop fan is not working.
kindly could you please suggest any solution or diagnosis to solve this issue please? thanks
RAJU_MSC_MATHEM
Zen Master I
Umar301
https://zentalk.asus.com/en/discussion/comment/165014#Comment_165014
If fan is running means, that means cable connection is disconnected in motherboard or fan is damaged , so I request you to take your laptop to nearest Asus service center ask the person to check laptop Hardwares.
