camera not working
logezh
System: ASUS VivoBook S14 S430FA
Battery or AC:
Model:
Frequency of occurrence:
Reset OS: windows 10 64bit
Screenshot or video:
Detailed description:camera in my vivobook is not working. it shows we cant find ur camera error code: 0xA00F4244
Blake_ASUS
Community Legend II
Hello logezh,
Was there any update or modification before the issue occurred?
Is camera listed in the device manager?
Have you checked your anti-virus program setting?
Also, if you enter safe mode, does the camera work?
RAJU_MSC_MATHEM
Zen Master I
logezh
  1. Battery or AC:
  2. Model:
  3. Frequency of occurrence:
  4. Reset OS: windows 10 64bit
  5. Screenshot or video:
Detailed description:camera in my vivobook is not working. it shows we cant find ur camera error code: 0xA00F4244<NOCAMERASAREATTACHED>
camera not working
same thing happend to me few times , culprit is some privacy services are disabled automatically, i am sure its not hardware problem, its purely software problem in windows os.
for testing purpose, install skype calling application, use webcamera in skype , see if camera works
