Battery draining issue in Vivobook X510UF
Cinderellaman
The Battery backup clamied by the company is about 8hr battery life Full workday freedom in Vivobook 15 X510UF but in realty it only last for 1.5hr to 2 hours maximum.the claim made is not upto mark please resolve this issue
4 REPLIES 4
Falcon_ASUS
@Cinderellaman
May I know when did you purchase your laptop?
The battery usage data of the laptop is based on low brightness and turning off unnecessary features (e.g., Bluetooth).
If you have any issues with the battery usage, we suggest referring to the following FAQ for assistance.
[Notebook] Troubleshooting - How to fix the short battery life problem (battery drains fast)
i have had purchased it in 2019 brightness is always low and keypad backlit is also off yet iam getting battery backup of only 1 -2 hour
@Cinderellaman
Considering that your laptop has likely been used for a while, based on your description, it appears to be caused by battery aging.
I would suggest you bring back your laptop to our service center for further confirmation.
ZenBot
Community Manager
Community Manager
