System: Windows 10
Battery or AC: AC
Description: Battery 255% available, plugged in and there is “x” battery indicator
Model: K403
Frequency of Occurrence: Always
Reset OS: No
Hello,
I use laptop Asus Vivobook K403FA.
The battery indicator shows 255% available plugged in and there is cross sign “x” in the battery display (left bottom corner) which is shown that battery not available. The laptop is just less than 1 year. When I plugged off the power adapter, Laptop will switch off straight away.
Anyone can help? Thanks in advance
