asus vivobook s13 s330fa intel wireless ac 9560 160 mhz error code 43
anton1a
Hi Zentalk forum members,
I need help :
System: windows 11 latest update
Battery or AC: both
Model: s330fa
Frequency of occurrence: ongoing
Reset OS:
Screenshot or video:
Detailed description:intel wireless ac 9560 160 mhz errorcode 43
I've tried disable device, uninstall device, update software, install driver from intel (, install driver from asus but still not solve problem. please help
ps. i try to post the url for driver download but cannot because i'm new
7 REPLIES 7
RAJU_MSC_MATHEM
Zen Master I
anton1a
I need help :
  1. System: windows 11 latest update
  2. Battery or AC: both
  3. Model: s330fa
  4. Frequency of occurrence: ongoing
  5. Reset OS:
  6. Screenshot or video:
whats the correct hardware ID
try below driver from below link
Windows® 10 and Windows 11* Wi-Fi Drivers for Intel® Wireless Adapters
anton1a
thank you for your reply Mr. Raju MSC. I've already tried that driver too. but everytime the wifi adapter connect to wifi network, code43 error.
appreciate your reply sir.
RAJU_MSC_MATHEM
Zen Master I
anton1a
Could you tell me the correct hardware ID
Falcon_ASUS
anton1a
I need help :
  3. Model: s330fa
  5. Reset OS:
@anton1a
Unfortunately, if you have tried reinstalling the driver and the problem still persists. According to what you described, please contact ASUS repair center in the country of your residence: https://www.asus.com/support/Service-Center-All-Countries/. Sorry for any inconvenience it may be caused.
